Manifold Studs + Nuts,Lambda sensor & 1 bar actuator
donpulsar
South Yorkshire Regional Rep
UPDATED :
Wanted ASAP!
1-8 Manifold Studs - Ordered from Nissan :cry:
8 Manifold Stud Nuts - Ordered from Nissan :cry:
Lambda sensor (3 wire, with or without connector) - thanks to J44MA for this :thumbsup:(if my R doesn't like the sensor I'll be in touch EssexAaron)
1 bar actuator (straight arm type) - thanks to KF79GTIR for this :thumbsup:
Please PM me or post below if you can help me out :thumbsup:
Cheers,
donpulsar :)
donpulsar
Am certainly interested in the actuator - what spring does it have in it / what psi does it runs at, how many miles has it covered and how much are you wanting to sell it for ?
Cheers,
donpulsar :)
donpulsar
Can the spring inside be swapped (like on the forge dump valves - is the end fastened with allen key bolts?) as from the link your one would be set to run standard boost and i need to run the actuator at 1 bar ?
Cheers,
donpulsar :)
