I recently got my car mapped and like other people I'm having problems with misfires around 1.7Bar. RC Developments dropped the plug gaps to 0.5mm and replaced my magnecors with standard leads (The rest of the ignition is all new Nissan and well earthed) to help and on the road all looks good which stopped the misfires at high revs.
However, on Saturday around Elvington, I was occasionally getting bad misfires in the mid-range. I'm guessing this is around the peak torque figure where I've got the most boost and pertol getting thrown into the cylinder and either blowing out or drowning the spark.
I don't want to increase the boost anymore, but I don't like being on the ragged limit of the ignition system. I've been looking round the internet at the options available. I quickly ruled out the direct ignition systems as too expensive/complex for my needs though arguably they are the best.
I also ruled out a patch job as after research I can see how ignition components are matched to each other so I need both a coil and amp.
I started looking for alternatives to the usual MSD solution and came across a Mallory system that seems to do the same thing.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MAA%2D6852M&N=700+0&autoview=sku
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MAA%2D30440&N=700+0&autoview=sku
Its a matched ignition system that should do the same sort of job as the MSD. It uses capcitive discharge to boost sparks power and duration with multi-sparks lower down the range for economy. Doesn't appear to need a ballast resistor and will be around £120 delivered. from what I've read the coil is designed to be effective to around 8Krpm. What am I missing before I decide to place an order.
Also, those who already have aftermarket ignition sytems and running over 400hp, what plug gaps are you using?
Cheers,
Jim
Cheers,
Jim
