Help!
Is it important to have the MAF sensor fitted in the factory orientation?. Have any of you done anything to the earth side of the wiring?
Mine is playing up i think. If i drive and any speed, or at any rpm over 2,000 and put my foot on the clutch, the idle dips down to almost stalling, then it will go to normal. The blow off valve seems to be adjusted and working fine, other things that make me think its the maf, is my thermo fans go on, and stay on until i disturb the airbox (custom made to cover pod filter) by "tapping" it, while the fans are running it seems as though the car is using alot of fuel as well?.
Any suggestions?
geeTeyeR
Any suggestions?
geeTeyeR
