MAF's
gunmetalgtir
Done a search but couldn't really find what I was looking for!
Can someone explain what these do (technically) and how do they work?
I bet Paul (youngsyp) gives the most longwinded answer! :lol: :-D
Rishi
Still waiting on some shims!
I couldn't be bothered writing it all out myself so i stole it from Wiki instead..
MAF
mass airflow sensor is used to determine the mass of air entering an electronically fuel-injected engine. The air mass information is necessary for the engine control unit (ECU) to calculate and deliver the correct fuel mass to the engine. Air changes its density as it expands and contracts with temperature and pressure. In automotive applications, air density varies with the ambient temperature and altitude, and this is an ideal application for a mass sensor. (See stoichiometry and ideal gas law.)
There are two common types of mass airflow sensors in usage on gasoline engines. These are the vane meter and the hot wire(GTiR). Neither design employs technology that measures air mass directly. However, with an additional sensor or two, the engine's air mass flow rate can be accurately determined.
Both approaches are used almost exclusively on electronic fuel injection (EFI) engines. Both sensor designs output a 0 - 5.0 volt signal that is proportional to the air mass flow rate, and both sensors have an intake air temperature (IAT) sensor incorporated into their housings.
When a MAF is used in conjunction with an oxygen sensor, the engine's air/fuel ratio can be controlled very accurately. The MAF sensor provides the open-loop predicted air flow information (the measured air flow) to the ECU, and the sensor provides closed-loop feedback in order to make minor corrections to the predicted air mass. Also see MAP sensor.
Vane meter sensor
A vane, or paddle, projects into the engine’s intake air stream on a spring-loaded arm. The vane moves in proportion to the airflow, and a voltage is generated in proportion to the distance the vane moves. The vane measures air volume, not mass, however by measuring the air temperature and pressure to determine air density, a true mass airflow calculation can be achieved. See ideal gas law.
The vane meter approach has some drawbacks:
it restricts airflow which limits engine output
its moving electrical contacts can wear
finding a suitable mounting location within a confined engine compartment is problematic
the vane has to be oriented with respect to gravity
Hot wire sensor (MAF)
A hot wire mass airflow sensor determines the mass of air flowing into the engine’s air intake system. This is achieved by heating a wire with an electric current that is suspended in the engine’s air stream, not unlike a toaster wire. The wire's electrical resistance increases as the wire’s temperature increases, which limits electrical current flowing through the circuit. When air flows past the wire, the wire cools, decreasing its resistance, which in turn allows more current to flow through the circuit. As more current flows, the wire’s temperature increases until the resistance reaches equilibrium again. The amount of current required to maintain the wire’s temperature is directly proportional to the mass of air flowing past the wire. The integrated electronic circuit converts the measurement of current into a voltage signal which is sent to the ECU.
If air density increases due to pressure increase or temperature drop, but the air volume remains constant, the denser air will remove more heat from the wire indicating a higher mass airflow. Unlike the vane meter's paddle sensing element, the hot wire responds directly to air density. This sensor's capabilities are well suited to support the gasoline combustion process which fundamentally responds to air mass, not air volume. (See stoichiometry.)
Some of the benefits of a hot-wire MAF compared to the older style vane meter are:
responds very quickly to changes in air flow
low airflow restriction
smaller overall package
less sensitive to mounting location and orientation
no moving parts improve its durability
less expensive
separate temperature and pressure sensors are not required (to determine air mass)
There are some drawbacks:
dirt and oil can contaminate the hot-wire deteriorating its accuracy
installation requires a laminar flow across the hot-wire
Cold Wire
LS1 and onwards engines (as well as others) use a "coldwire" MAF system (produced by AC Delco) where the inductance of a tiny sensor changes with the air mass flow over that sensor. The sensor is part of an oscillator circuit whose oscillation frequency changes with sensor inductance; hence the frequency is related to the amount of air (CFM) passing over the unit. This oscillating electrical signal is then fed to the car's ECU. These MAF units (such as the one pictured) have 3 pins, +, - and F, the F contains the square-wave frequency between - and F.
The mesh on the MAF is used to smooth out airflow to ensure the sensors have the best chance of a steady reading. It is not used for measuring the air flow per se and it is not recommended that you "clean" these units other than ensuring the wire-mesh is completely flat and free of any debris. Manufacturers claim that a simple but extremely reliable test to ensure correct functionality is to tap the unit with the back of a screwdriver while the car is running, and if this causes any changes in the output frequency then the unit should be discarded and an OEM replacement installed.
Membrane sensor
An emerging technology utilizes a very thin electronic membrane placed in the air stream. The membrane has a thin film temperature sensor printed on the upstream side, and one on the downstream side. A heater is integrated in the center of the membrane which maintains a constant temperature similar to the hot-wire approach. Without any airflow, the temperature profile across the membrane is uniform. When air flows across the membrane, the upstream side cools differently than the downstream side. The difference between the upstream and downstream temperature indicates the mass airflow. The thermal membrane sensor is also capable of measuring flow in both directions, which sometimes occur in pulsating situations. Technological progress allows this kind of sensor to be manufactured on the microscopic scale as microsensors using MEMS technology. Such a microsensor reaches a significantly higher speed and sensitivity compared with macroscopic approaches. See also MEMS sensor generations.
I didn't think the GTiR AFM had any way or means of measuring air temperature ?! And certainly not air pressure (that would be a MAP sensor)?! As i understood it, it's a simple resistance measuring device...
Paul
Rishi
Its not messuring the temprature or pressure.. The Hot Wire is reactive to the changes in air density as a result of changes in Temp and Presure..
Fusion Ed
The way the (hot wire) MAF works means by its nature it measures the amount of air (i.e. Moles) and so temp / pressure are not required to work out the density, as it can be done directly.
Edit rishi already answered...
As I said..... The GTiR AFM simply uses a hot wire that changes it resistance reading, as air flowing over it increases and decreases.
So that article you posted up is talking crap ?! :lol:
Paul
Rishi
Paul
Where does it say any different..? :confused:
Round about here:
RishiGTiR said:
MAF
Hence my original post. ;-)
Paul
