loom wiring?
dumpstar85
hey, ive just put a new gearbox in and ive got to wiring it back up, got a couple of spare plugs at the back of the engine which need homes but i cant see for the life of me where they are supposed to go.. 3 round 4 pin plugs.. which branch off from the same section where the starter motor subloom branches from the loom at the rear of the engine.. has anyone got a 3d drawing of socket locations so i can get a virtual idea of where to shove my hand!
Nice one, much appreciated. Rik
pschurr
Ok, the image you've referred to is not a GTIR.
The diagram you want is on EL-212 here...
http://www.gtirworkshopmanual.com/default.aspx?v=2391
At the back of the engine on the Engine Loom, starting at the gearbox side and moving towards the drivers side, you have...
neutral and reverse switch connector (E228),
starter motor connections (E219)
speed sensor connector (E229)
detonation sensor (higher) (E216)
fcid and air regulator solenoids (E230, E232)
oil pressure sensor (E233)
and then you have the two coolant temp sensor connectors.
peter
dumpstar85
thanks loads.. il head down my unit and crack on.. that online workshop guide is smart as... really handy, thanks alot matey
Rik
