Look What I've Found-T28 3" Dump Adapters
Sirnixalot
there is one word that is synonymous with that place....ESPECIALLY with fittings....frustration.
You are ordering big stuff so you should be ok though 8)
R
rsnissan
Hmmmmm this could be useful..............why didnt you find this 3 weeks ago lol
zia
is this the v-band adapter? you,ll still need to make the dumppipe to the mongoose, and also there might be problem of turbulence when the waste gate opens into the flow path? still i suppose it better than stock :lol:
zia
Mr GTiR
that's what i'm worried about now.... :cry:
would be nice if we could weld in a 1" pipe inside the 3" coller to flow the wastgate gasses away.
skiddusmarkus
Got this reply:
Simon,
Take 12% off for 10 or more.
Shipping 10 should be about $55-65. They are heavy little
suckers.
ATP
Have emailed again to see if they have 10 in stock and how long to ship them.
RE turbulence etc I think it's a big improvement over standard and will be a lot cheaper than having one made up.
stevepudney
GTiROC CHAIRMAN
Simon
I'm interested, but how do you plan on fitting anything (dump pipe to mongoose) to it ???
I do have an idea but just want to see what your plans are first :wink:
Steve
C
ChrisR
Order one of their short 90 degree v band elbows and weld that to the mongoose/downpipe.
Chris
GINGA
If you used that adaptor and downpipe section together with a modified ebay s14 manifold (Sorry Nikko :lol: ) you could even still keep the aircon :D
C
ChrisR
skiddusmarkus said:
http://www.atpturbo.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=ATP-MDP-002&Category_Code=MDP
This is the mandrel bent 90 degree peice I'd use.It comes with a clip for joining to flange.Total cost would be just under $200 plus shipping for both parts and an o2 bung.You'd then have to either have a flange welded onto end of it to mate to downpipe or weld them together.
I think I might go ahead and order mine and see how they work out.
Yeah, that's the one. I've got one here if you want any dimensions or anything from it?
Chris
ashills
hope u dont mind me showing u what i found the other week
this is built for the gtir rally cars
its not a standard angle elbow but its so nicely flowed etc
it has a very nice seperator as u can see
but only slight problem is that iit is 3.5" outlet so it needs a reducer welded in
and its not cheap at over 175 quid
im having a play about at making my own turbo outlet but if it doesnt come off soon ill just get this before totb and i know its about as good as is avaliable sorry about pic quality it was done on my phone lol
stevepudney
GTiROC CHAIRMAN
IMAGE NOT AVAILABLE
Where are these available from, looks just right and £175 isn't to bad
