Longer Wheel Studs
billy187
A mate needs longer wheels studs on the back of his car to get his wheels on, any idea what size the standard studs are and what size he should get?
Even better would be some links to ones you lot have bought? There are quite a few different ones on ebay...
Also will the studs just knock out?
Billy
darkyGTI-R
The actual bolts that the nuts go onto there is about 3 in total loose i noticed it when i took wheels off tried to tighten with fingers but to no avail?
olliecast
the splines is the plural of spline. my error matey.
you could knock out the studs and check the splines matey
vss irvine
Some of my studs are loose how do you replace them?Are they easy to get out and what tool do you use?please:der:
depends if your leaving the hubs on the car, when i changed mine, i stripped and rebuilt the hubs at the same time.
they have to be knocked or pressed out
olliecast
if your not using them again i`d knock them out with a small lump hammer, if your using them again then i`d press then out to avoide ruining the threads
