Lightweight flywheels
stumo
I've used the search but found nothing...
Someone has said that a lightweight flywheel for an American spec 200sx(S13 with SR20DET) is the same as the GTiR?
I was under the impression that the S13/14 flywheels only had 6 bolts and the GTiR has 8, am i correct or not?
Shaun
Hi mate, a 200sx has 8 bolt holes the same as the 'R's flywheel,just the are a smaller diameter.
Rishi
Still waiting on some shims!
Ok... There are 200SX's that use the 8 bolt configuration... They generally tend to be the later cars... S14a and the S15... The only thing you need to do is ask the machine shop to widen the bolt holes for the GTiR...
Rishi
