The AFR graph I got from my run at the Surrey dyno day, showed the car was running very lean across the whole rpm range, richening up when under load but, still in the high 13 range.
After plugging in Conzult and armed with other information, the conclusion was that the fuel pressure was low (very) across the board, under load and not under load.
At the time, I had a stock fuel pump (93k miles old), being fed with full alternator voltage. Naturally, this was the first area to improve on. I've now replaced it with a 255lph Walbro pump, still being fed full alternator voltage. I also checked the fuel filter, to confirm it wasn't blocked.
I've today, checked the fuel pressure and it was around 3.3 bar with the vacuum pipe disconnected and 2.8 bar with the pipe connected. The gauge was placed, inline, between the fuel filter and fuel rail. The FPR also responded well to throttle inputs (stantionary with vacuum pipe connected obviously), with blips of the throttle, causing a 0.2 bar or so, blip in fuel pressure.
The question is, is 3.3 bar about right for 'base' fuel pressure ? As, I thought it was supposed to be 3 bar ?! Or, is that what you' expect with the higher pressure pump ?
Also, should I expect the FPR to behave, as the fuel pressure gauge shows ?
The car does feel a bit more punchy and, the exhaust emissions do smell different too (couldn't really smell them before).
I will get the car dynoed again, just to confirm AFR's are ok, Thorney Motorsport are just up the road and they have a very nice looking dyno cell, with dyno dynamics rollers !
Paul
Paul
