hi guys, well basically i was testing out the launch control on the power fc and now the car runs like a sack of sh*t.
- will not start very easily, cranks but sluggish and catches very slowly
- very lumpy idle
- loud tick/knock coming from round by the plenium every few secs- and worse if i give it a little blip. the engine will be running; abet lumpy then it will go knock... normallish for a second or two then knock again. its loud cross between a tick, click, knock and a klonk.
breakdown guy, said it sounded like it was backfiring back through the inlet manifold - could be the timing chain jumped a tooth.
i did a compression test, all came back around 145psi, spark plugs were black but normal, no smoke on idle from the exhaust, checked all the pipes i can see and all look ok, although i will check again in the morning.
any other ideas of what i could have done :?:
- very lumpy idle
