larger injectors.
  • Thread starter gotoinstant-redline
  • Start date
gotoinstant-redline
evening,
i'm thinking of getting some larger injectors to go with the rest of my mods (loads of em) so that i can run more power (why else!)
is it possible or safe to just get some 700cc injectors and stick them stright in? woudl this cause any probs? will the car still run? or will i need some sort of engine man' system to keep them working properly?
cheers
L.
GINGA
NO :!: if you do that you will overfuel very badly which will cuase at best poor running and at worst fcuked engine through bore washings,petrol in oil etc :shock:
If you fit larger injectors you have to have some form of fuel controller fitted and set up at the same time with apexi s-afc or unichip being the cheapest options with the unichip being the better of the 2 choices as the timing can be adjusted to :wink:
SickBoy
Wot diference would larger injectors make to just a 1.2 bar "R" if any if set up with a unichip ????
