Larger Injector fitted on GTiR OEM Fuel Rail
cmng
Hi..
need to know any brand and injector 600cc above can fitted on GTiR OEM Fuel Rail
any aftermarket fuel rail available for GTiR ?
i cannot found any on web.
if got worth to change it ?
The list i manage to get those injector can fitted on GTiR OEM fuel rail
without adding resistor
Nismo 600cc
HKS 600cc
SARD 700cc
Power 700cc
Please correct for me if i was wrong here since afraid buying the wrong injector only
any other brand can be used ?
Thanks
GINGA
I've got the sard 700cc injectors in the standard fuel rail, there a tight fit but do go in but probably better with slight smaller O rings than the standard nissan ones :wink:
cmng
Sirnixalot said:
www.jgycustoms.com for the rail...its very nicely priced, i have the very first one made....so you're welcome :p
Yes, i have see that one,
but dont know whether i should go to their custom fuel rail plus MSD 72 lbs injector
or just upgrade to those japanese injector which also carry the same cost overall just slightly cheaper only
GTI-R Kid
Thanks SirNix. knew i could rely on you for the answer. 8)
