boucherie
as im going to be running a blowthrough setup on the R i just want to check this out first before i go for it.
the new maf and dump vlave t piece are 75mm diam compared to 63mm IC pipework. as the total length of this new pipework is about 12" would that be a sufficient distance for the boost pressure to drop off and then pick up again when it goes into a reducer before the intake manifold.
could this potential to 'lose' pressure (as its spread over a larger volume) cause the engine to run irregularly as it would be thinking that a certain flow of air was passing through when in fact the pressures would be different or am i over exaggerating the point entirely?
