Chiffs said:
:search:
http://www.gendan.co.uk/product_O23WIRE.html
:-D thats what someone on here used
The R Lambda sensor is titania rather than zirconia which are more sophisticated and more expensive (Roughly double) no matter what car its for. It says Titania in the maintenance manuals for our engine which is fairly conclusive. My Lambda was purchased from Nissan and performs like a Titania, also.
They are not interchangeable on a standard ECU or PFC so I would be interested to know if and how they got that to work.
A quick search to confirm my thinking taken from the SR20 forum, I've bolded the key point:
All in all, you have to use the correct O2 sensor for the ECU you are running, there are two different types of o2 sesnors car manufactures use, do a search I posted info on this if wanna find out (TITANIA VS ZIRCONIA 02 SENORS) AKA Fat and Skinny, by the way TITANIA sensors are mainly used on high end cars as they are more expansive and faster responding.
charlie2020
07-30-2005, 12:52 PM
But they are not interchangable IIRC
TITANIA works off of wide range of varible resistance and
ZIRCONIA works off of a scale of 0-1 volt and the ECU is therefore programed accordingly to reach a specific o2 sensor.
