Knocking
K
KRS
Just the once?
Sometimes it can pick up on other sounds and register as knock, but I would keep a close eye on it incase you have a problem.
buffalobilla
its just happend the once and the car jerked a bit when boosting, then afterwards went back to normal and stopped knocking :?
K
KRS
Were you going round a corner? Could have been tank surge causeing you to run lean for a sec.
K
KRS
Sounds like it was fuel surge, Were you low on fuel?
First time it happened to me was frighting cause the backend stepped out without warning.
K
KRS
I had a similar amount, Its not uncommon in the R.
I think you can get anti surge tanks to stop it, but personaly... anything that slows me down into the bends is a good thing ;)
Im only guessing this is the problems, if you were giving it into the bend, i would assume im right :)
