Ever since I've had my gtir I've had a knocking from the front suspension (both sides but more noticeably from NSF)
I've always thought it's the strut top mounts (as I've had evos and they are prone to it and it sounded exactly the same)
Tonight I took the top mounts apart (again) and seeing no real noticeable problem areas I made up some plastic washers between the bearing and spring top seat to see if there was slack (in the only place that'd casue noise)
No joy, still exactly the same and the complete top mount is tight as a drum so I'm certain now it's not them (as there wasn't even a change of the noise)
I've also (previously) replaced the anti roll bar bushes and drop link bushes (more from when I was just refreshing things) so I can count those out.
The shock absorbers themselves are not leaking, they are very 'new' feeling ie movemen is nice firm with hard suction/resistance both ways.
I've checked the drop links (when I changed the bushes) and couldn't get any movement out of them or noise, also tried the bottom ball joints. Again when I had an Evo I had a similar noise which turned out to be drop links but there was very noticeable movement in them, on the gtir they seem tight.
It's really annoying me now! I know these threads are a bit pointless really as it's a guessing game so not really sure why I'm posting haha!
I'm going to buy some drop links now and try those.
