Hello all
I just picked up my new pulsar its black has an ap organic clutch,full mongoose exhaust with de cat and a cone air filter. and apart from the wing having a dent in it very tidy both inside and out;-)
just drove it 185 mile home it drove without fault still had a quarter of a tank of fuel left too;-)
i have one quick question i did do some searching but couldnt find answer, on the std boost gauge it boost's to the end of the boost gauge and reads in some form other then bar or psi is this standard pressure or raised if the needles is reaching to the end of gauge?
there is no bleedvalve or ebc plumbd in so im assuming its running standard boost unless the rod has been wound out on actuator, all the pipework on boost circuit looks fine ie no leacks.
my next thing will be to find out what fuel pump it is running then get it set up to run a bar if its not already.
