Internal gearbox upgrades
Hello all, I went down to Llandow circuit this weekend and after a long drive down from Leeds in Yorkshire, my gearbox failed in selecting gears properly again after a massive 10 f*****g minutes on track. It didn't select 3rd properly, then was stuck in 4th, then would select nothing and now I believe it's stuck in 3rd.
Now it's a quaife gearset I have in, and I'm sure I've tried before but not got anywhere, is there uprated springs, selector forks, synchros or anything else I can put in to make it better an more reliable and if so, where can I buy this stuff!??? Lol!
For those that know me, this time it wasn't driver abuse as I was actually just driving it steadyish and getting warmed up and used to the track!!
Thanks Chris.
Who (re)built it? - I'm sure I've read a couple of times where something really simple like a detent wasn't quite in place and as a result the whole box locked up.
It's done a few track days and been to Nurburg since its last build so I don't think it's that pal! It just needs more new.... Better bits to go with the quaife gearset! I was just wondering who knew what was good and what's around, and were to get it! I've got 2 weeks to get it all done as I'm booked on at Croft 2 week on Sunday!
3/4 par selector.
The the problems that you will most likely find it that now you've added a Quaife, the stresses and strains will be transmitted into other areas of the gearbox.
I had exactly the same issues when I went to the Isle of Man. I added a Quaife and the gearbox still destroyed itself because the power was transmitted to weaker parts of the transmission.
All I have done is replaced most parts brand new and also cryo treated them for what it's worth.
johnny gtir
So are new springs etc availible ? Bearings any info as also looking to build a box up ? What's on at croft Chris ? Our special or just a track day ?
Yep, it's annoying when the other parts keep breaking! I didn't realise that the gearbox internals were still available from Nissan brand new! I shall buy whatever, springs, new synchros etc that I can get from Nissan and get them cryo treated. And I shall buy the 3rd to 4th and 5th gear Par fork selector then! I guess I will just have to get it built 1 more time with standard parts that I have in a spare gearbox so it will be ready in time for Croft, and then get it all done again properly after that! :)
Croft is just a track day Johnny, booked through javelin! I'm in mine, my mate in his supercharged s2000, my dad in his Abarth and my other mate in his Ibiza cupra! U booking on matey!? Obviously the more the merrier! It's Sunday 17th April! :)
Thanks for your help Andy! :)
whytie
1st & 2nd Synchro - oem 3260179E00 / replacement 3260179E10
3rd & 4th Synchro - oem 3260503E15
5th Synchro - 3234439E15
1st gear assembly - oem 3223054C04
2nd gear assembly - oem 3225054C04 / replacement 3225154C14
3rd gear assembly - oem 3221556E00
4th gear assembly - oem 3221729R04
5th gear assembly - oem 3231039E10
The springs are
3rd and 4th x 3 of them oem 3260903E01
1st and 2nd x 3 of them oem 3225979E00 1990 to 1994 and 3225979e20 1994 onwards.
The ring baulk's .
1st 3260780S00 upto 1992 then 3260780S60 1992 onwards
2nd 3260479E00 upto 1994. Then 3260479e20 1994 onwards
3rd and 4th 3260403E15 or 3260479e10
Thanks matey! That will be really helpful as I'm just about to ring Nissan now! The parts numbers will be very helpful! :)
whytie
The synchros can be found easily enough on the net, I don't think you even need to goto Nissan for them
