Interior Carpet
gtirx2
I think the carpets are slightly different from the ra/rb models.
If you are not using the plastic under floor heating to the back you will proberly need an rb carpet as the ra carpet is slightly bigger so the heating pipes fit under it.
Not really much of a problem but the ra carpet can look a tiny bit loose without the heating pipe pushing it out tight.
Think this applys more for the drivers side around the hump in the floor than the for the passengers side.
