Doesn't the ATTESA system in the GTiR just incorporate a series of differentials? It's about the most basic one they made because it was one of the first iterations, and although it has the same name is not in any way related to the Skyline version.
<Clicky>
I don't see how it could ever transfer 100% of the power anywhere; it just does a torque split for each wheel and then another one for each axle - whereas the system in other cars (like the Imprezza) uses a hydraulic LSD to adjust the proportion from a standard 80/20 front rear bias (although Holden use a 20/80 split in their AWD systems to keep the tail heavy feel).
Anyway; as I read it the Pulsar will give you 25% of power to each wheel (like a real 4WD car as opposed to an AWD car), and as soon as that wheel starts to spin it takes the power away from it and sends it to the other wheel. Likewise back to front; but you'd be working pretty hard to spin one axle without the other one spinning too - that's why it feels like it's bogging when you do a hard launch; it's splitting the power equally to each wheel, which means that they won't spin... or they'll all spin (which is a spectacular sight).
I've never seen my ABS light come on under this kind of situation, but it has when I've stomped hard on the brakes. I've seen the traction control light come on in other cars, but my old girl doesn't have one of those.
