Intercooler pipe run
whytie
This is far from ideal but running out of options, do use guys think 180 bend will be to extreme
whytie
I rotated it 90 degrees and also 180 degrees, still no much room due to the 3" exhaust elbow.
Just need to have an other wee think in the morning.
STEVEN878
Is this the black gtir you showed me a couple of weeks ago mate?
how much bonnet to manifold clearance do you have.....enough to put the boost pipe above the manifold?
whytie
Aye that's the one at the back of the drive collecting dust, no clearance there the manifold is to big.
Ill rotate the turbo again and sort something out.
velly4
I think the angle coming off the turbo is worse than the 180 degree bend. I have mine facing down out the bottom, looping around the dump pipe.
whytie
I had to make that pipe at a funny angle as it had to bend straight away for me to get bolts into the turbo.
I'm going to try a different route next time I'm at it.
whytie
I was actually just discussing that with a mate, no room for movement coming on and off throttle.
If stood looking at the front of the car I moved it to the right, then made a new bracket that bolted to the gearbox bell housing bolts, gives you a load more room.
