we drilled and tapped the plenum for the spa boost pressure/temp gauge, gives you the best readingi have a front moutn intercooler but hate they way they fit/look.. i used to run a charge cooler setup on my 5 tub and it kept the temps down at around 30degrees..
im thinking a bigger enough pre rad and also the top mount ic would still be able to keep the temps low and not have any pressure drop/torque loss due to a massive long pipe run...
maybe i will have to try it and let everyone know how it goes when i get my car back...
we ultimatly need some inlet temp sensor...
also does anyone have a actual inlet manifold boost nipple (ow er) plumbed directly in to see actually what the engines getting boost wise...?
keith
