hi , hope all is well.
i just wondered if anyone could help me i have been installing the safc on my car along with avc-r
firsty i connected the safc and then started the car to make sure it worked i however forgot to disconnect negative terminal before installing however it still started then i fitted the avc-r but into to the harness and not the engine side of things, and it started fine
then i soldered everything then it wouldn't start and the controllers didn't come on also
i changed the ecu as i think i damaged my original one, and the controllers came on but the car doesn't start, i have spark from coil but just doesn't start
i know i probably damaged my standard ecu by not disconnecting the terminal but i have checked all other fuses and still it wont start, also i tried disconnecting the red wires from the controllers to see if it would start with out but it still doesn't,
any idea what i f***** up.
thanks for your time and help.
sam
sam
