hi !
i got all my parts complete so i can start my rebuild in the next days.
what torques and procedures do you use for ARP studs/bolts ?
i found different topics on sr20forum. and also some people dont
recommend ARP parts. for example the head studs are not same length
as the standard ones. so they might fail.
i also found bad posts about cometic head gasket.
what experience do you have with ARP parts ?
what about cometic ?
or should i use standard parts ?
so far i got:
COMETIC head gasket 87.00
JE pistons 87.00
ACL main bearings
ACL rod bearings
ARP head studs
ARP main studs
ARP rod bolts
bronze valve guides
all new gaskets/seals
new oil pump
new water pump
new chain+tensioner+guides
JUN 272 cams
JUN uprated springs
thanks for any info
so far i got:
JE pistons 87.00
ACL main bearings
ACL rod bearings
ARP head studs
ARP main studs
ARP rod bolts
bronze valve guides
new oil pump
new water pump
JUN 272 cams
JUN uprated springs
thanks for any info
