Injectors
bopper
Hi all i want to buy some injectors from the states im dealing with rc engineering and they just sent me this email. wondered if anyone could answer the questions
Hello Dean,
Your 1994 Nissan Pulsar injectors looks like it's a side-feed type
injector. The injectors are similar to the Nissan Sentra type as well.
We specialize in top-feed type injectors, so we may not have any
injectors for your application. Is there any way you can send us a photo
of your stock injector? That would be helpful. For the resistance, we
tested them in Peak and Hold-Low resistance only, so if you have a volt
meter, you can test to see the ohms. If the injector is between 2-3
ohms, you need a Peak and Hold-Low resistance injector. If your injector
is between 12-16 ohms, you need an Saturated-high resistance injector.
Here are the closest dealers near zipcode, 32830:
rayman75
the injectors are top feed ones, why are you getting them from the states? what size are you after?
cmng
forget about getting from States for injector
US prolly using different kind of injector model that will NOT DIRECT FIT to
that why they have to change the fuel rail when they upgrade to RC, MSD type injector
a fuel rail will cost about USD 150 exclude shipping
