Injectors maxed out?
Mondorno
This is my current setup:
Hybrid FMIC
Mongoose turbo back system with decat
Apexi Air Induction Kit
Walbro fuel pump
HKS 264° camshafts
Iridium spark plugs
running std. boost
I checked my injector duty via a Blitz R-VIT and it is at 98% from 7000rpm till redline!
How comes, that people run more than 1 Bar of boost, without uprated injectors?
Is that with a standard turbo? Even taking into account that you've got 264 cams you'd never be maxxing out the injectors at that boost on a standard turbo so i'd say thats wrong!
Mondorno
Yep, std. tubby
The R-Vit measures injector spraying time
the injector will squirt every 2 revolutions so
8000rpm is 8000/60 = 133.3 rev per second = 66.6 squirts per second
so time available for 1 squirt is 1/66.6 or 15ms
The R-Vit shows 14.8 ms from 7000rpm till redline
Fusion Ed
Personally speaking that perhaps at 1 bar would not surprise me. Pulsars tend to run a bit rich when mods are done to them, and I have seen many max out at little over 1 bar. How much boost however are you running you say stock but do you mean stock actuator? or stock with the original boost valve.?
Fusion Ed
Reason I asked is many people get mmhg confused with bar. However your probably running very rich, unless you believe your blitz to be lying.
