Hello guys.
So...bumped into this big problem.
I know that I discussed and over discussed in some other thread but I need some help A.S.A.P.
The turbo fits without any problems but the actuator wont fit by any means.
I took a longer rod, center it, weld it.....made another actuator bracket so the actuator wouldn't be close to the manifold or the turbo.
This was 3 days work time (2 hours per day) and now ...NO RESULTS....
I've tested the actuator to see how it works at approx 1 bar pressure and the gate opens approx 25 degrees, I HAVE HAD ENOUGH!!!
Now I want to tap the the manifold weld a 90 degree neck and a flange for an external wastegate.
Please advice on :
-how should I blank the internal wastegate
-what external wastegate should I buy ....38mm , 44mm ????
Please note that the turbo is an GARRETT GT3071R Internally wastegated
Please advice on :
