I'm Lost Help :S
SIR GTIR
Hey everyone
finally got round to putting all my new gear in
GT3071R
Sard 800cc injectors
Z32 AFM
PLMS daughter board
turbo smart FPR
well i got the turbo on and got the car started after that tho i had a slight vac leak from the breather hose that runs to the intake
so then i started putting the Afm injectors and Ecu in after that it's Not going
I've got spark
had a Plug out seemed that they were wet (May recheck)
it's fired once or twice but then only cranks over done a diag 55 so thats all good to any ideas People ?
Is the ecu actually mapped for the Z32 & 800's or did you just chuck them in and hope it would run :lol:
samgtr
you have to get it mapped to run those injectors and z32 you have fouled the plugs , you will need to torch the plugs to clean them, then get it set up.
Sam
SIR GTIR
Ya i've done all that
been mapped by a good tuner thats tuned a good number of R's
Alienprobe well known in N.z forums
mate came over with his consult cable
It's now throwing 2 codes 11 and 21
crank angle sensor
and
ignition circuit
Seems now that theres no spark so i'll have to see weather i can borrow a coil off a mate
as for the cam angle sensor Don't know as the engine was running fine before the turbo swap
SIR GTIR
Well it's running again
ended up being the ecu i used
after a little help from a Mate of mine we swapped the daughter board over and after having fun trying to get the ecu to reset and start without bringing up the code 11
