identify turbo
turbodaily
anybody know where abouts the serial no. usually is on the gt turbo's? is it a plack or just punched in somewhere? guessing thats the only way to identify exactly what model my turbo is, gt28rs or a gt2871..?
exactly same as below with 4" inlet
turbodaily
seems to hit full boost around 3700rpm. its major sarcasm's old turbo, he seemed to think it was a gt28rs but im not 100% convinced. mainly due to spool up time, thought a 28rs wouldnt be as laggy as 3.7k rpm?
ashills
probably a 2871 it was ordered from jgy by the owner before major as far as i remember as i bought loads of bits off them same time as him a few years back now
cmng
Possible to measure the compressor wheel size from the housing ?
from there you roughly know the turbo size and spec
Braveheart
I have a GT2871r and the serial number is on a small plate between compressor housing and turbine. Think the compressor housing can vary depending on what you order.
Some turbo suppliers fit the OE Pulsar compressor housing for the GTiR...
The P/N on my 2871r is 743347-0002
turbodaily
i had a look earlier and couldnt see any plack, unless its on the backside where i cant see it.. mine is the same as the one above ie. not original style comp housing.
Braveheart
With my turbo fitted, I can't see the plack as it's on the back side facing the engine block between oil and water feed.
turbodaily
comp wheel sizes
GT28RS/GT2860R
GT28RS
1.86"/47.2mm inducer
2.37"/60mm exducer
62 wheel trim
gt2871
1.94"/49.2mm? inducer
2.79"/71mm? exducer
48 wheel trim
