ideas? car loosing weight (pics added)
antilag
rite on another mission i want the car to weight in the 1000 kgs
so suggest for things for me to do bearing in mind i have done all the usuel and alot more
antilag
things removed and estimates of weight loss
sound deadining 25kg
all plastic interior parts 10kg
roof lining 1kg lol
rear seats 3kg
all door cards 5kg
bonnet change 3kg
rear wiper 3kg
doors are now hollow with no electric parts 20kg to 30kg
windows bolted shut
no aircon system 20kg
no heater system 10kg
lighter wheels and suspension i think?
all electric switches ect included there
and more......
memski
Queue Nikko.....
Realistically 1100kg is a better aim for you, unless you go all out with carbon fibre panels everywhere (££££) and completely remove EVERYTHING you won't need. Good shit though, let us know how you get along 8)
antilag
yeh but im certain im close to late 1000kgs now tho if the car was 1220kg that is
1
1000ny
remove dash
replace all body panels with fibre glass (or carbon fibre if you`re feelin flush)
get hair cut (it all helps)
remove all but one seat and swap the drivers for a carbon fibre bride one
carbon steeing wheel
carbon gear knob
remove all green neon kits from underside of car (don`t pretend like you aint got em)
i`ve just took the engine out of mine and its light as a carbon fibre feather, but that would only work if you`re making the car lighter just to make it lighter not faster :?
Sirnixalot
ive lost about 120-140kg from my car but its not livable to drive every day
trust me...the road noise is deafening...and the car was being towed....no engine on! Imagine it with the engine at full song...ear plugs 8)
roof lining 1kg lol
rear seats 3kg
all door cards 5kg
bonnet change 3kg
windows bolted shut
and more......
did you lighten all the brackets that held the air con and every other bracket as they are all over engineered :wink:
remove the front anti-roll bar :shock: trust me you`ll never notice it`s gone :wink:
lightweight nuts,bolts,washers.a gram or 2 from every nut,bolt and washer will soon mount up but will be expensive :shock:
aerospace/F1 spec engine wiring loom :shock: will save a couple of kg`s
geetee
replace the glass with cling film or polycarb :D
replace the sterring wheel with a large pretzel :lol:
GeeTee 8)
geetee
well if you get stuck in a snow drift or summat - at least you won't starve to death.
I'd advise wearing a pair of those g@y driving gloves to stop ur sweaty palms making it go soggy though :lol:
GeeTee 8)
antilag
these were b4 the sound deadening was removed and just add the dash and wheel back on minus all the heaters ect
removed rear window surrounds to
Muppet
could you make some polycarb rear quarter windows. should not cost too much.
do the same to the rear hatch as you have done to the doors.
regards muppet.
Mr GTiR
Websnowbo said:
There's only ONE way to loose weight and thats loose metal.........
you better get the drill out and start to swish cheese the inside of your panels :wink:
seen it done on a stripped out GTiR and it looks mad once done :shock:
paz
you thought about changing all your windows for that clear plastic (forget its name) like in some rally cars?
Body panels in fibreglass would potentially give you the biggest weight loss I would imagine.... have a look into changing your wings and also the possibility of the boot as well :shock: maybe remove the spoiler (although I know you won't want to) as I imagine thats pretty heavy.
Paz
