In theory it shouldn't be hard to turn it - it's a matter of losening the bolts that hold the compressor housing to the rest of the turbo-doohicky, and then turning the housing. In real life it can be problematic it seems, due to actuator configurations and whatnot. Depends on your configuration I suppose.
Yes that will melt as stated above!
I'm not sure if hard silicone hoses will withstand that sort of heat even with the heat shield there it still fooking burns my hands when I need to do stuff in the engine bay!
i had that problem with my pipe work touching the manifold and the catchcan, i just slackend the bolts on the compressor housing and turned the pipe into the right place and retightend
I had this problem when I went to castle combe and it burnt through the silicone and i had no heat shield on mine. I had to buy a new bit of pipe from merin motorsport ( castle combe on site shop ) and I lagged it up. Basicly, that will blow very soon!!
