Stevo said:
whats the next spec after the standard R turbo?
is it the same manifold but with different turbine and housing sizes??
or is it one of them mad turbular manifold?? :?
all depends on what you want and what you intend doing with the car :?
you can get the std turbo modded to a roller bearing as a 1st step which will give good results without costing the earth
but,you might need to upgrade other things such as injectors,brakes,clutch etc
don`t be surprised to see this moved into the tuning section very shortly
