turbodaily said:
get turbo rebuilt with 360 bearing (turbo suppliers call a stage 1) and you'l be sorted
Don't bother with the 360 degree thrust bearing, that's a very old tech solution. For very similar money, you should go for a ball bearing core rebuild. If you want to go that extra mile, get the housings ported too.
When they hybridise a turbo, they usually cut back the blades of the turbine, to reduce lag. But, I think this will affect the efficiency range of the turbo and probably lower the amount of boost it can produce. With a ball bearing core, there's really no need to cut the blades back as, it will spool up that much quicker anyway.
AS for the fuel pump, there's a guy over on the modifiers club who sells 255lph pumps for around £50. These are effectively the Walbro pumps (same internals), without Walbro stamped on them. You can also get these pumps on eBay for similar money.
Before you do that, it might be worth hard wiring your existing fuel pump in as, it'll only be seeing around 12 volts as opposed to 14.4 volts and that will reduce flow and so pressure. Do a search, there's a thread on it somewhere !
