If they were both 300 bhp and in the same car there wouldnt be a difference in actual performance :lol:I'd like to know how different the Mitsubishi 2.0 turbo engine from the evo 9 is to the SR20DET in actual performance if the BHP is the same say 300bhp
The MIVEC system works on just adjusting the timing by essentially rotating the cam much like the Rover VVC system. The VET system has separate cam lobes like VTEC and is a far superior system.The EVO will have a 4G63 MIVEC engine; so that's variable valve timing which the SR20DET doesn't have (the closest alternative is the SR20VET from a JDM X-Trail)
With engines of teh same capacity lag will have more to do with the turbo strapped to the engine and the mapping, but the evo will probabley be slightly better stock for stock as it has a higher CR (8.8:1 vs 8.3:1).what about differences in turbo lag etc?
standard pistons as you say mark were actually pretty good, the problem with all these cars is the mappers that didn't know what they were doing.If you stuck say a gt30 on both engines I don't think there would be a great amount of difference in response and the power produced. Both engines have their good and bad points, the rods are a lot better on the sr20 and I don't think the standard pistons are as bad as people have made out over the years ;-)
What was wrong with the original maps? Say compared to modern mappingstandard pistons as you say mark were actually pretty good, the problem with all these cars is the mappers that didn't know what they were doing.
My standard pistons took 399 bhp for over two years before the ring lands went on one of them, Which was quite handy really because we caught the crank bearings just intime to stop the crank getting damaged.standard pistons as you say mark were actually pretty good, the problem with all these cars is the mappers that didn't know what they were doing.
The Pulsars run very rich so their is plenty of scope for a good mapper to not only save fuel but to get a lot nicer car to drive.What was wrong with the original maps? Say compared to modern mapping
My car has been reasonably close to that sort of power now on the original 134,000 mile engine since October and (touch wood) all is still well. Don't know the exact power as i never bother with dyno figures. Its done god knows how many track days, sprints, hillclimbs, airfield days in the 8 1/2 years i've owned it too which just goes to show what a good engine it is when looked after properly ;-)My standard pistons took 399 bhp for over two years before the ring lands went on one of them, Which was quite handy really because we caught the crank bearings just intime to stop the crank getting damaged.
It's all about good maintenance and efficient heat control, If you achieve these two things then their is no reason you good old SR20 wont give you plenty of happy miles of trouble free motoring, If I where you Mark the only thing I'd be worried about is the condition of the crank bearings.which just goes to show what a good engine it is when looked after properly ;-)
Same here,i had a chat with the owner of vandervell bearings a few years ago and appaentley the standard aluminium over steel nissan bearings are not very good, they can work harden and then fail and also they will be prone to deformation without the ability to return to original shape (due to aluminiums nature from heat cycles of work hardening) which means they will fail.It's all about good maintenance and efficient heat control, If you achieve these two things then their is no reason you good old SR20 wont give you plenty of happy miles of trouble free motoring, If I where you Mark the only thing I'd be worried about is the condition of the crank bearings.
John
Forgot to mention cooling, i've got a uk car so the radiator is twice as thick as a standard one. Add to that the 19 row oil cooler and thats probably been a major point in making the engine last so long!It's all about good maintenance and efficient heat control
