GTIR-LOZ
hi ive been tarting up my R and removed the vacuum lines and now i cant remember which ones go where i have the one off the plenum to the actuator the fuel pressure reg with the boost guage and contoller attached to it comming from the back of the plenum,where its split by a t piece and also gos to the factory boost sensor, the vac hose off the back of the plenum to the top of the carbon filter or whatever it is and the dump valve comming from 1 pipe on the back of the plenum
if you can follow all that is this correct or is it routed wrong, i fitted a painted inlet manifold and have set up the rods on the inlet manifold and it seems to idle at 1500rpm and if i touch the throttle it seems to die and then come to life then die again, if i floor it its ok
any ideas
any ideas
