Hks
Mr B
Would be better getting a custom exhaust made to your requirements, will be cheaper & better performing & loud/quiet as you want.
Buying a used Mongoose & converting rear to silencer with standard or nearside exit (better pipe run) is a cheap way of have a good exhaust & your requirements ...
HKS exhausts are stupid money, maybe a second-hand one can be sourced !
http://www.templetuning.co.uk/nissan-pulsar-gtir-exhaust-systems-201-c.asp
http://www.invo-tec.com/products/exhausts/exhaust-systems/nissan/pulsar-gti-r/hks
skiddusmarkus
It will be the same as all the others, there isn't that much choice underneath.I think the HKS ones were mild steel too.
Mr B
HKS pipe route is like image below (image is not HKS but pipe route is run same)
Kakimoto runs inlet & outlet pipe same end & U bend is in Silencer.
turbazz
oh i see..a lott of bends forget that! rather have a custom goose less bends,left exit, stainless,bigger diameter and cheaper!
suprised a big company like hks do such a poor system. jasma is just a sound certifaction?right...dont mean its s/s correct?
Mr B
Jasma (Japan Automotive Sports Muffler Association)
HKS do a variety of exhausts some better than others in terms of material & performance gain but none worth the price tag.
As I said in my first reply Goose with custom rear box & left exit is way to go & a neat job of cutting out 2 equal squares in bumper (one being original tail pipe exit & one being area of new left exit) & swapping & plastic weld can make it look like factory original exit ...
A good job on a original right exit with 3" or slightly larger would probably not result in much performance difference, would like to see results of each on RR dyno ...
