HKS manifold gt3037kit
Thor
a little big for the GTI-R?? so the full boost is at 6000rpm i mean... is very very late...
cheers
Sascha
cmng
i posted this before
i doubt the manifold is HKS
HKS manifold basically cannot see the external welding on the pipe
pete-r
It says gt3040 not 3037.Going by experience i just wouldnt buy a second hand turbo,not unless its freshly recon,d with proof.Just save your pennies mate and buy something new.
Rishi
Still waiting on some shims!
cheers
Sascha
The GT3040R can be on full boost by 4000rpm quite happily...
Rishi
Thor
wow really?? so my GT3037S has full boost over 4000rpm.... i mean my is smaller than the GT3040 or not??
Sascha
Rishi
Sascha
Yours has a smaller compressor wheel to the GT3040R... You need to adjust your setup to get it to spool quicker...
Turbo spool up time is also dependant on other things...
  • Engine Capacity
  • Engine Compression
  • CAMs
  • Gas Flowed Head
  • Porting
  • Port Matching...
  • Turbo Turbine Housing
  • Induction
  • Manifold diameter and length
  • Boost limit
  • Boost Duty
  • Fuel Map
  • Ignition Timing
There is more but you get the idea...
Rishi
