slammed_gtir
Hello people, my car seems to idle very high at around 1500rpm is this a common problem and a easy fix?
Thanks
Thanks
do you have trouble spelling the word idle then ?slammed_gtir said:well to behonist mate i always search first, im just not very good at it .
If you search around the forum, you'll see exactly where to look !slammed_gtir said:cheers mate problem is i just dont know my way around the engine or where to start looking, is an air leak most likley to be it or is it more common to be something to do with the idle conrol unit?
Just out of interest, what did you use to make it ? And how did you make it ?Cambridge_pulsar said:There was a thread on here about making a boost leak tester, I cobbled one together and straight away found 3 leaks, 2 very small ones in vacuum pipes. Well worth doing and will make finding small leaks a lot easier.
