oddbodd
hello there
just a quick qs i have had a rebuild at hi teq in wigan a man called ian top man. i was wondering if any 1 out there has had a simler or the the same build cus i have only done 900 miles so far i have 2 do 1500 before i take it back for a service and but the boost back to .7 and a 1bar 2 settings the car is only running .55 bar cus he turned it all down 4 running in the spec is
hks pistons
hks cams 264
lighten balance engine assembley
1.2 metal head gasket hks
water pump
oil pump rotors
knife edge crankshaft
mains & big end bearing set
engine gasket kit
head bolt set
arp con rod bolt set
cut valves seats
And that is it i would like to now if it will be quik cus this running in killing me i went out with my bro in his running 0.9 and anoter lad running 0.8 and i kept up with them so hopfully i will be loughing
O and i have a front mount FORGE.
cheers have a good new year
hks pistons
hks cams 264
water pump
oil pump rotors
engine gasket kit
head bolt set
cut valves seats
