Having quite a few problems with my pulsar GTiR, only had it a few months and its drivin me mad!
Firstly, getting the ignition timing set is turning out to be a bit of a nightmare. I do the whole routine as described in the serivice manual then set it to 20deg BTDC and it runs like a pig. If I set it without doing the routine it seems to run pretty fine - is this normal?!
Also recently, I seem to be getting oil shooting out of what I assume was originally a breather pipe on the rocker cover but is now a small air filter directly above the ignition coil.
On top of this I have had problems with my tachometer not reading correctly all the time, sometimes it'll shoot up as high as the redline. Had the ecu out and bypassed the signal wire in the loom from the ecu to the tachometer with another wire to see if it was that but it was giving the exact same dodgy readings. I assume its the feed from the coil but am not sure which wire on the coil goes to the ecu? Also will this affect the ecu's running of the engine if it thinks the engine is running higher rev's than it actually is?
Sorry for the long list, any help would be greatly appreciated!
Cheers guys
Clarky
Cheers guys
Clarky
