help with gearbox
... my problem is:
i cant change gear.. the 3 gear is on what ever gear i turn the shift to..
if i turn the shift to gear 1 ... the 3 gear is on.....
i can move the shifter to all gears but the gearbox does not change gear...
whats wrong?
hope you guys understand my bad english..
plz i need help...
jasegould
If the linkage is still connected and you can select all the gears from but are stuck in 3rd then its an internal gearbox problem, prob a 3/4 selector fork as these are known to break. Ive just replaced a gearbox on a Vauxhall with the same problem, it was a fault with the baulk ring.
is it hard to change 3/4 selector fork ??
how much does it cost? part nr?
ok thanks Jasegould.. i think you have right..
I'd agree with Jase. I'll mean a 'box re-build as far as I know so budget for a new clutch, etc unless it's been done recently. You might aswell do it while the box is out.
Dunc
... im going to change the clutch...
butt is it diffecult to change the fork?
i dont think its too hard.
i looked at mine the other day. just getting the box out and all the rest is the hard bit.
