HELP TOMCATS GOT ME
My r is holding back at low revs, gets better gradually then takes of a 4500rpm. Took it to P.T.S they came up with two fault codes, the first being the knock sensor and also the air flow metre, so i have changed both but still no joy....If anyone has got any ideas i would be well up for listening.... having tomcat turbos on my bumper is not a happy place for me...... Thanx :( :eek:
Assuming the new afm is working, it could be a problem in the wiring, or earth and the chances are it might have been causing the det problem too. :?
hiya.... do you mean the wiring that plugs into the afm? :D
It can be that wiring, or the wiring anywhere upto there.
The fault code indicates a problem with a component, it's wiring harness or connector. :wink:
Right ok then mate thanx for that think i may try my hand at a bit of soldering..... Got the wiring from a scrapy off another r. thanx
