str_motorsport
hi, i got a problem with my R that is really making me crazy!!basically the car runs fine, but after about 30 min of driving, especially on low boost and revs, the car start to run bad, and it seems it don't want to rev ,it has very slow throttle rsponse until it reaches full boost.....but the EGT temps goes high even for a short acceleration...
i tried everything...
new plugs, plug wires,dizzy,dizzy cover, fuel pump,ecu, maf,relais,trhottle sensor....everything!!!
changed the fuel pump power supply also....
the only thing that i have not tried is the det sensor and the cas and coil ...but there is any fault code on the ecu....
i start thinking i will never solve the problem...
ever had a similar experience?
please help me if you can
thanks
David
thanks
David
