I’m looking for some help. I got a Unichip fitted in October last year. It made no difference to the performance and I was told after it was set up that is was because I had worn cam shafts (RUBBISH). It was running around 300bhp when it went in and came out with 150bhp which only appears around 4500rpm and drops off. When I got the car back I checked for fault codes and it showed CAS. Fitted a new dizzy, set the timing and it ran ok but was still lacking power. I then put it to another tuner and 7 weeks later and a lot of ££££'s I have it back still not working but with around 200bhp the power still doesn’t come up until 4000rpm and then drops away again. They fitted and mapped a Z32 MAF but on idle if you tap the accelerator it wants to cut out. I have since changed this for another and the car won’t idle it’s just over fueling. I used the wiring in the how to guide but found a few variations B-signal C/D-ground E- +12v is how it’s connected. Today I have changed the ecu and tried the standard MAF but it’s still doing the same. Any help would be gratefully appreciated before my IBC of petrol ends up spilling inside it and my fag accidently falls out my mouth.
