Right let me explain my problem i hope someone has some ideas
My car now and then does this thing when on full throttle only!
Im in any gear at low rpm and but my foot right down, the car hesitates but does NOT miss fire!, if i build the speed up its fine. Now i have changed the following
plugs
leads
coil pack
turbo gaskets
DET Sensor
And i still get this problem, now to fix it i do a ECU code check it comes back 55, so i reset ecu and car is fine for about another week.
Now im running a unichip :lol: (came wiv car ) will this have anythink to do with my problem?
When i do a reset set what does it do to ecu apart from clear and fault codes? does it reset the unichip?
I can only guess its the air temp are to hot as i have standard i/c and a induction cone behind battery, would the AFM sensor be faulty?
HELP :lol: :lol: :lol:
plugs
leads
coil pack
turbo gaskets
DET Sensor
