Glyn
I've just read from the FAQ how to re-ground the MAF but I don't fully understand If you solder a wire to the middle pin of the maf (then take this to earth) how do you get the plug back on for the other 2 wires :?: If it means solder wire to the plug side, do you then cut the origional wire going back into loom :?: When I checked the middle wire with the meter (on tickover) the reading was 16.7ma. If I can bring this way down should I see an improvement in running... :?: It's far from 100% at the mo and ecu not responding to fault code check. any help much appreciated :?
