Matt Evans
I'm trying to change the clutch lever, but I can't seperate the clutch housing from the engine. How do I do it?
And the one under or near the starter, you can just about see it from underneath the carTheres a few bolts that its easy to forget about I usually forget the bellhousing bolt on the bottom of the engine
You're not wrong, when I did the starter for the first time it was a real pain in the a** (though I could do it much easier now) the worst thing was I had to pull my gearbox out a week later :x.Getting the starter motor out without dropping the engine would be a pain in the a** let alone removing the speed sensor, and getting that bolt.
thats why I think its easier to drop the engine,JohnnyGTiR said:You're not wrong, when I did the starter for the first time it was a real pain in the a** (though I could do it much easier now) the worst thing was I had to pull my gearbox out a week later :x.Getting the starter motor out without dropping the engine would be a pain in the a** let alone removing the speed sensor, and getting that bolt.
Done with the engine in the car I managed to get a ring spanner on the prick bolt and using a long bar as a lever, apply enough pressure to crack it. Then its just the painful task of undoing it like 1/8th of a turn at a time (probably easier with a ratchet spanner).
I dont think I've ever before bled that much from the knuckles.
