help me...!
my problem is that i cant change the fanspeed (the fan in the car.)
i can only use speed 0 = fan is off
4 = max speed
whats wrong and what should i do to fix it?
is there anyone haveing the same problem?
plz help me....
GINGA
I think theres a resistor or something that fails so you only get the full fan speed but thats all I know about it :oops:
one Gti-R
pull the console apart and chech behind it to make sure the connection is ok.
have checked behind it... and it was ok.
where can i find the resistor... to the fan speed?
/Ilskog
jaigtir
try ringing mjpauto.com on 01277 374201 if you need the parts.
jasegould
The resistor should be relatively close to the fan, possibly in the airstream from the fan as it gets hot. Follow the big red positive supply to the fan and you will find it....usually a white ceramic block with wires coming out from it.
On my montego it was mounted on the body of the heater, and a small black plastic square in that case.
... damn i think im blind... cant find it.....
can some one help.
GINGA
Yes that should be the one, easiest way to check is to unplug it and if the fan stops totally that should be it, but just check to make sure the wires from it go to the fan to :wink:
