HELP ME PLEASE!!!!
APGti-R
im getting quite a bit of smoke out the exhaust, it only happens when im slowing up for a corner or roundabout. any suggestions???!!!???
is it ma turbo on its way out?
any suggetions would be most appreciated guys.
cheers in advance
Olly
What boost you running? Do a compression test first then go from there, many things can cause that but most commonly ring land failure but fingers crossed it isn't chap 8) if its turbo seals, when its all cold take the turbo elbow off and you might see oil dripping down the exhaust housing off the blades. :shock:
