pulsar-kid
went out last nite for a blast in the R and all was ok let it warm up headed on to this fast bypass was doing around 50 ish went to over take a car dropped into 3rd floored it but as i was gunning it it strated to hesitate and like die and come back then i remebered that my battery had gone dead so i replaced the batt, as i was going i checked my avc-r hadnt lost its settings and that the boost had this showing in the setting mode ******% so i set it back to 1.0bar but it was still hesitaing a little, so i thought better head home but it got worse even under boost it judder and in boost it was treable so i got home and checked the pipes they looked ok for what i can see and checked the plugs they are a sandy colour so what can it be, big help please guys as i have a couple of mates with scoobs taking the piss at the mo as its playing up
oh i watched the boost gauge as it hesitated it went up to 15psi then dropped to 10 then back to 15psi mods to the engine are,
mines ecu,
greedy e-manager blue,
full goose inc decat,
hks filter,
apexi avc-r,
hks blow of valve,
new nissan leads,
set at 15psi,
standaed i/c
and when i had the garage swap the engines over the standard boost gauge doesnt work and i swapped the gauges over and still no vacum it does regester 0 when the ignition comes in
and what should a healthy pulsar oil pressure run at when its warmed up and driving around very slowly
mines ecu,
hks filter,
apexi avc-r,
hks blow of valve,
new nissan leads,
set at 15psi,
standaed i/c
